how to read intersense wireless inertiacube3 in LabVIEW?
I am using intersense wireless inertiacube3 for my school projects. I want to import its data to labVIEW, so for that purpose I have created a program in LabVIEW. I have attached the LabVIEW VI, that I created and specifications document about the intersense wireless inertiacube3 device.
Please let me know, how to read this device in LabVIEW. And how to correct my VI.
I know that the control characters I used in the array (named array) on the left are not right, if so then what should be the new characters, so that I can import this device in LabVIEW.
Thanks in advance.
(3,370 Views)
Hey kalmegh,
Have you taken a look at this forum post about the Intersense Wireless Inertiacube3? Did you make sure that the device is able to communicate over RS-232 with your machine in the Measurement & Automation Explorer? This tutorial on Serial instrument control will also help you out in your programming.
I hope this helps 🙂
David G
Sales Engineer - SE Michigan & N Ohio
(3,363 Views)
