how to set an AKM servo's zero angle position as home
    I'm using a PCI7352, an UMI7772 and an AKD P00606 drive to control a servo motor AKM54H. Because the home input of the UMI7772 is not connected so the find home function does not work properly. But in the AKD WorkBench software the angle of the position can be seen by clicking the feedback 1 tab. Is there anyway to control the servo motor in labview to move to the zero angle position without adding additional encoders? Thank you for your answer.
(5,657 Views)
I have solved the problem,use the find index function.
(5,648 Views)
