how to set x-axis of waveform chart to be real time
sir
    how to set the x-axis of waveform chart/graph to be real time.
   DAQ assistant block is used to aquire the analog signal(voltage), that chages with different load.
this voltage signal is required to capture and i am trying with waveform chart/graph.
but i am facing the problem of setting the X-axis.
 can any body help how to set the X-axis of wavefor chart/graph ?
Message 1 of 1
(5,710 Views)
