how to use UMI7774 to control motor
Hi I really need help here...
I am using PCI7344 and UMI7774 to do simple control of a motor to make certain movements.
Right now I have completed the wiring of feedback from motor encoder and managed to see encoder readings in MAX.
But when it comes to the analog output from UMI7774, i can't measure any signal from there while i am sending commands from MAX, hence my motor can never be driven to move.
Below are some of the information of the components that I use: motor:ElectroCraft S240-1A8
        motor amplifier: Advaned motion control 12A8E
I tried connecting voltage into REF+ and REF- of the motor amplifier, and the amplifier make the motor moved. The larger the input voltage, the faster the motor spined. The same if I switched the polarity, only direction of movements changed. So there was no problem with motor ot motor amplifier.
Here I got two majot problems to be solved:
1. why there is no analog output from the UMI7774 board even though I sent command from MAX?
2. if I want to wire up the UMI7774 and motor, i connect "Analog output"(pin #1) and "Analog output GND"(pin #9) from UMI7774 to the amplifier REF+ and REF- respectively right? is there any other connection that is necessary?(I have attached the datashee for my motor amplifier so that you can take a look and help me out)
(5,817 Views)
I have not used MAX for a while now but I remember there are some basic settings. One setting is for setting the board to drive servo or stepper motors, make sure you selected the right item in this menu.
(5,801 Views)
I did set that part as "servo motor". One thing to be added on, when I use labview DAQ assistant to creat some Analog Waveform and test the analog output pin at UMI7774, but Labview just tells me that "no device available".
It is wierd because I can see PCI7344 in my MAX, and through connecting feedback from motor encoder to UMI7774(which is again connected to PCI 7344 using motion I/O), I can see the readings of motor speed and position in MAX.
Wierd, isn't it?
(5,789 Views)
