how to use the two output analog signal from DAQ6015 to control a stepper motor?
Hi friends:
please help me sort out this problem, please find the attchment. and in the block diagram, there is more information.
all i want is the pulse it generated with time(frequency).
cheers
dan
Message 11 of 12
(1,310 Views)
Hi Dan,
I just sent you an email but to carry on from that, have you considered using a counter to control the speed of the motor?
The Gen Dig Pulse Train-Finite example (browse to Hardware Input and Output >> DAQmx >> Generating Digital Pulses in the Example finder) does what you require. If you want to look at the signal you're generating you can configure an analog channel to look at it.
Sarah
Applications Engineer | National Instruments | UK & Ireland
Message 12 of 12
(1,296 Views)
