implimentation of a fuzzy logic contro on fpga
Hello
I am a beginner in labview fpga and I want to achieve a fuzzy controller to control a DC motor. But I can not find the solution that sancfant that I use a card devlopment "digital electronics fpga board".
and i wanna also creat a pwm signal in this board .
thank you.
I will be very happy if you answer me as soon as possible
(2,472 Views)
first get accustomed with the logic of Labview, and especially Labview FPGA. You need to create your fuzzy ouputs by combining logic blocks (like comparison, greater/smaller et.c.) with probably a lookup table, where the fuzzy data will be stored and also an I/O block.
What is your hardware setup?
(2,444 Views)
thank you .
but nowi would to start by creaing a pwm signal output in my board National-Instruments-Digital-Electronics-CCA-193426B-01L-FPGA-Board.jpg
(2,436 Views)
