I've got an PCI 7352 Card connected to an MID 7602 Drive. The problem i wanted to solve is the following:
...after a system start, I wanted my stepper motor to run to some offset position using the onboard-programming and auto-start-enable vi's for the Motion Card , but every time i have a power cycle on my pc i'll have to do it all manually again via MAX...looking into MAX after such a power cycle tells me that the Card hasn't been initialized...is there a way to initialize the motion card with the onboard programming features just directly at the beginning of the system start (power cycle) without using MAX or a Labview program? Writing the Initialization vi into the Flash will cause me an error message -89506.
using:
WindowsXP
LabView 8.2.1
NI-Motion 7.5
