is the PCI-7356 compatible with PCI-X
Hi, can i plug the PCI-7356 motion controller card in a PCI-X slot ? I don't find it in the list of compatible NI cards, but it has got a double notch in its connector...
And if it is so, can i still connect it to a 5V powered UMI7764 ?
Kind regards
(3,477 Views)
For NI products the double notch at the PCI connector always indicates compatibility to PCI-X. The +5V power supply on the UMI is used to power some circuitry on the UMI and it will not cause any harm to the 7356.
I hope that helps,
Jochen Klier
(3,474 Views)
