labview interface with arduino
hi every one, iam doing a project based on motion controll. i have an arduino ,a 4 wire stepper motor and designed driver using uln 2803. stepper motor is working properly when i use arduino board. now i want a interface with labview so that i can have a front panel to control the stepper motor. i tried to connect with the example stepper motor. but i need help and advice. there is a stepper pin option in arduino module , so what should i have to enter whether its a constant or control ?? And do i need to enter the 4 pins output of arduino. pls give me advice
(5,246 Views)
Hi
     You can just use NI6009 DAQ to start is good .
And VISA DAQ to drive the Inputs of your chip 2803 .
(4,973 Views)
