loop in motion assistant specified number of times?
I was wondering if in motion assistant I can do a loop in my script so that each movement can be repeated many, many times without having to create a new 'step' for each movement? Any help is appreciated.
Nichole
(3,244 Views)
Nichole,
Motion Assistant does not currently support loops in its environment. What I recommend is that you create your steps with just one pass and then add the loop in the code Motion Assistant generates.
Rodger S.
(3,239 Views)
Thanks Roger!
(3,216 Views)
