motion controller for globe E-2620 motor
What is the correct NI controller/motor drives for a pair of Globe Motor E-2620
DC Permanent Magnet Motors with Optical Encoder?
Motor Specs:
P/N 537A244-3
24VDC Motor Voltage
3.1A Max Rated Load
HP HEDS-5500 Encoder
Russ Smith
(3,476 Views)
Hello Russ,
Thank you for your interest in National Instruments.  For the DC Permanent Magnet Motor you specified you will need one of our brushed DC servo motor drives: 7652 (2 Axis of control) or the 7654(4 Axis of control).  The controller hardware you need will be dependent on what other features you need for your motion system you are building.  The two options for controlling these types of motors are the 7340 series and the 7350 series.  To see the differences in these two types of motion controllers go HERE.  Let us know if you have anymore questions.  Thanks and have a great day.
Mark T
(3,464 Views)
Mark:
Thanks, I appreciate your prompt response.
Russ Smith
(3,460 Views)
