motor code
I took the example Velocity Profiling and modified it for two motors, the error came out said no Board ID are wired, but they are wired. Can anyone check the code for me please?
Thank you
CKH
Message 1 of 25
(7,386 Views)
Please ignore the first post, I found another sample than can control 2 axes at the same time, this is exactly what I need. However, the motors will not stop after i click the stop button, I have to run another program to make them stop, is there any way I can fix the issue? Another question I have is, how can I make 1 motor run CW the other one run CCW?
Thank you
CKH
Message 2 of 25
(7,378 Views)
Message 3 of 25
(7,377 Views)
Hi there. Let me try to answer your questions.
1) To stop the motors, you have to include a "Stop Motion.flx" function outside of the while loop. This way, when you hit the stop button on the front panel, it exits the while loop (that's what the stop button controls), and then the "Stop Motion" functions execute and stop the motors. I've attached modified code that should accomplish that.
2) To go the other direction, try putting in a negative velocity.
I hope this helps. 🙂
Ravi A.
National Instruments | Applications Engineer
Message 4 of 25
(7,364 Views)
I didn't attach the file. Woops! A classic mistake.
Ravi A.
Message 5 of 25
(7,363 Views)
Hi Ravi,
Thanks for the reply, I solved the direction problem by adding negative sign on the step poistion, I'll try the velocity as well.
Thank you,
CKH
Message 6 of 25
(7,361 Views)
Hi Ravi,
I tried to put the stop motion into my vi, but the motor still moving forward after I hit the stop button, I have to go to MAX manually reset the poistion "Reset Position button". Is there other way that I can stop the program whenever I want?
Thank you,
CKH
Message 7 of 25
(7,339 Views)
Hi Ravi,
I solved the stop button problem now, but is there a way to reset the position to 0? After I stop the motor and try to run it again, it will pick up previous position and continue the count from that specific position, I know I can try to reset it in MAX, but just wanted to know if there is any easier way to do.
Thank you,
CKH
Message 8 of 25
(7,332 Views)
Hi CKH,
So right after your Stop Motion.flx VI, you can put a "Reset Position.flx" VI, located in the Functions Palette at Vision and Motion >> NI 73xx >> Trajectory Control. The attached screenshot shows you where it is. If you'll notice, the functions around here provide many control options for your motor, many of the operations you perform in MAX.
Ravi A.
Message 9 of 25
(7,326 Views)
Hi Ravi,
Right now I am looking for much simpler way to switch the motor direction, from CW to CCW, I'm thinking making a switch do the work. I know I can just mannually added a negative sign in front of the target position, but I think if I can just add a trigger switch function, this might be easier. Is there any way to do it, I was thinking duplicate the same code but using "negative sign" times the "position" to make it negative target position under "case structure".
The following is the vi I created before adding the trigger switch.
Thank you,
CKH
Message 10 of 25
(7,319 Views)
