motor speed in max
I have already setup for test but still i am could not correct couminication. Are you useing any timer with EQ( echo queuing)?
1) How to monitor Read Position "PA"?
-Thanks
Message 11 of 16
(1,531 Views)
I'm pretty sure that I had the ECHO turned off.  To get position, the command is "1R(PA)", assuming address=1.
Message 12 of 16
(1,526 Views)
I am working (for the first time) with the ViX500-IM Drive.  I ran across this feed and found the attached LabVIEW Vi's to be of great interest, however, these VI's (when being opened & constructing their respective Block Diagrams) are trying to find a another VI Library file by the name of "ViX.lvlib".  Does anyone know where I might locate this particular VI Library file?
Thank you.
Message 13 of 16
(1,315 Views)
Hi Jim-
I must not have included the library in the original posting.  I have many other VI's, but havn't looked at them in years.  If you need more help, let me know.
Brian
Message 14 of 16
(1,311 Views)
I just looked at the library.  Most of the useful VI's are in there.  Some of them are specific to my application.
Message 15 of 16
(1,310 Views)
Brian,
Thank you for your quick response!  I have two questions:
I have not used this forum before & when I go to download the ViX.lvlib file, the browser opens it up & shows me the text contents instead.  I can't seem to find the option to download this file like I did your previous four VI files from the earlier (2 year old) thread.  Can you help me out here please?  Could you send it as an attchment to me at jim@sentekcorp.com??
Also - the four VI's that I was able to download from the 2 year old thread were:
ViX Config Comms.vi
ViX Parse Message.vi
ViX Read Com Port.vi
ViX Write_Read.vi
Were there any additional VI's for the ViX500 Drive that would be useful from your created library??
Thank you so very much!!
   Jim
Message 16 of 16
(1,299 Views)
