08-17-2015
01:50 PM
- last edited on
04-24-2024
09:39 AM
by
Content Cleaner
Hello Everyone ,
i am looking a solution for my problem :
- A use AKD driver with Brushless motor
- NI motion 7344 : https://www.ni.com/en-us/support/model.pci-7344.html
- Ni DAQ - PCEI -6363 : https://www.ni.com/en-us/shop/model/pcie-6363.html
I use AKD with the NI motion to drive the motor and , i want measure at same time 4 analog input with PCEI
I Use this
08-18-2015 04:04 PM
Hi k-usa,
I would check out the periodic breakpoint example that ships with NI-Motion. You can find it under Hardware Input and Output » Motion Control » NI 73xx » Capture and Compare » Periodic Breakpoint Output.
This will output a digital signal on the 73xx that will match the encoder. You can then put a wire between this output and an input on your device. Finally, configure your DAQmx task to use the input on your 6363 as the sample clock. This will synchronize your measurements with your motor.
Michael Bilyk
08-19-2015 07:22 PM
Hi thank you for uou reply
Now it works , I also did some mistake whem I tried to manage the DAQ.
I have anaother problem : who can I get the index of the encoder ?
I use this : but sometime i have error 70123 ?
How can I fixe it ?
08-20-2015 04:38 PM
Where is the error occuring?
08-24-2015 09:07 AM
At the end of execution of programm....
08-24-2015 09:10 AM
Hi k-usa,
Could you probe the error wires on your VI to determine which function is causing the error?
Michael Bilyk
08-24-2015 09:15 AM
It is Wait Reference.flx
