my application needs to control a motor in current moder
hi
I have an application where i need to control a motor in current mode. I have an anlog input in my drive which is used to specify the Amp/Volts. I want to control this application using 7344. I have the encoder feedback from the motor and hall sensor feedback (U,V & W). How do I connect these feedback to 7344 to establish the current mode control of motor
(3,039 Views)
The key here is going to be the amplifier you are using to drive your motor. There are mainly three variations of servo amplifiers our there, namely position amplifiers, velocity amplifiers and current amplifiers. However, the forst two types are just specializations of the thrid one. Most amplifiers these days have the capability of being configured for torque mode either by switches or software. What kind of amplifier do you have? If you can send us the specifications as well as the model, I would be able to give you detailed instructions on how to set up your system.
(3,039 Views)
