myRIO with AMC motor drive
Hi everyone, Im trying to use myRIO to send PWM signal through AMC drive to a DC motor.
I want to use the PWM pin of the motor drive
http://www.a-m-c.com/download/manual/AMC_DZDrives_InstallManual.pdf
can anyone tell me if it is possible to use this pin to control the motor or should I use RS-485 to comunicate with the motor drive?
Thank you
(3,383 Views)
Hi Mosio 79,
I'm not sure about that specific drive but the myRIO is capable of outputting PWM on its digital lines. There's an Express VI that comes with the myRIO toolkit which generates PWM on the PWM pins on the myRIO. I've linked the help here.
PWM Express VI
http://zone.ni.com/reference/en-XX/help/373925C-01/myrioreference/myrioref_exp_pwm/
Austin
Staff Software Engineer
NI
(3,348 Views)
Thank you very mich for your response,
However, my problem is with the drive and im not sure if i can use that PWM from myRIO to control the motor with that drive.
(3,345 Views)
Hi Mosio79,
It looks like it will depend on the drive and I can't speak definitively about that, but it looks like the PWM input should go to P1-17 and the Direction will enter P1-19. This is described in the PWM and Direction section (2.6.4) in the document you linked. I'm not sure how you will need to configure the drive, but that should describe the hardware connections at least. It looks like it is possible. If you have any further questions, it would be helpful if you could provide the model of the drive you're using. Thanks!
Austin
NI
(3,331 Views)
