no motion examples
I would like to dig in some examples relating to the motion module, for instance the 'Current Loop - NI9505'.
I Installed the latest version of Labview, FPGA module, RT module, Motion Module and NICRIO drivers.
When I look in the examples, I can see the 'Current Loop - NI 9505' example but if I dubble click on it to open I receive the message: 'That file could not be found or opened. You may need to reinstall your examples'.
How can I reinstall these examples?
(2,882 Views)
Hello sambuls2,
You should follow a process identical to the one described here: http://digital.ni.com/public.nsf/allkb/CA27535CCC93674086256E0B00784CBA just with a different software package.
Best,
Nick
Everything has an End, and you get to it only if you keep on
-E. Nesbit
(2,833 Views)
