nulogic drivers
I have 2 old Nulogic ISA boards model "PC STEP4" that I need to install on a Win 2000 machine.
Does anybody have drivers for these boards.
And are these drivers compatible with Windows 2000.
In case they are not, are there equivalent boards that would have the same functionality?
And in that case how much Labview changes do I need to make (Version Upgrade, data acquisition software)
This issue is holding one of my production test stations down, so I would greatly appreciate your help.
(3,209 Views)
Here is a link to the last version of the ValueMotion driver (version 5.0.2) to be released:
http://digital.ni.com/softlib.nsf/websearch/68E44A959190305F86256A5500685480?opendocument&node=132070_US
It does support Windows 2000 and I believe it will also supports your nuLogic ISA boards.
The upgrade path from your board would be the PCI/PXI-7334. This motion controller uses the latest NI-Motion 6.1.5 driver. The driver supports LabVIEW 6.x or newer. The API between the to boards is different so your software will need to change. To see the API differences refer to the following documents:
ValueMotion to FlexMotion Conversion, Part I
http://zone.ni.com/devzone/conceptd.nsf/webmain/13417A1EBCF29AC686256AD2006920C7
ValueMotion to FlexMotion Conversion, Part II
URL:http://zone.ni.com/devzone\conceptd.nsf/webmain/511DB99E804CDF7886256AD200760ECF
Rodger S.
(3,206 Views)
