09-10-2012 06:27 AM
I work in a lab with a tensile testing machine controlled by a LabVIEW program (made by myself). The computer connected to the machine is too old and slow, so we're replacing it with a new one.
To measure and control all the things we want (motor, extensometer, force sensor), we use two cards: a PCI 6220 and a PCI 7342, both from NI.
What I've done so far is taking the cards from the old PC and installing them in the new one (having all the things I need already installed: last versions of NI Motion, DAQmx, MAX, VISA, etc.).
When I start the new computer, Windows shows the assistant window to search the drivers for the two cards and everything seems correct. The two devices appear in the Windows Device Manager list (see attached image).
The problem is that NI MAX doesn't detect the PCI 7342 (but he does detect the 6220). I've refreshed a thousand times, switched the cards (connecting the 7342 to the PCI port where the 6220 was, and the 6220 to the 7342 port), updated all the drivers... I honestly don't know what else to do.
Here are my system specifications, I hope someone can help.
Sorry about the French (I'm a Spanish student working as an intern in a French company, so the computer is in French), I think all the words here are easily understandable.
Système d'exploitation (OS) Windows XP Professional
Version de l'OS 5.01.2600
Infos OS Service Pack 3
Processeur Intel(R) Xeon(R) CPU E5420 @ 2.50GHz / x86 Family 6 Model 23 Stepping 6 / GenuineIntel / 2493 MHz
Nombre de processeurs 4
Mémoire physique 1,99 Go de RAM
Disque C:\ 9,93 Go sur 26,0 Go libres
Disque D:\ 47,6 Go sur 48,4 Go libres
Logiciels National Instruments : Version :
CVI Run-Time 10.0.1.434
NI-DAQmx Device Driver 9.6.0f0
NI-DAQmx ADE Support 9.6.0
NI-DAQmx MAX Configuration 9.6.0
NI-488.2 Software 2.46
NI I/O Trace 3.0.2f0
IVI Compliance Package 4.4
LabVIEW 8.2
LabVIEW Run-Time 10.0.1
Measurement & Automation Explorer 5.3.1f0
NI-Motion 8.4.0.3000
NI Motion Assistant 2.8.0
Measurement Studio Visual Studio 2010 Support - See individual versions below.
DotNET
Common 12.0.40.253
Common (64-bit) 12.0.40.253
NI-USI 1.0.2
NI PXI Platform Services 3.0.3
NI-PAL Software 2.9.0
NI System Configuration 5.3.0f0
NI-VISA 5.1.2
NiVisaServer.exe 4.0.0.49152
NIvisaic.exe 5.1.2.49152
NI-VISA Runtime 5.1.2
LabVIEW Run-Time 11.0.1
LabVIEW Run-Time 7.1
LabVIEW Run-Time 8.0.1
LabVIEW Run-Time 8.2.1
LabVIEW Run-Time 9.0.1
Thanks a lot.
09-10-2012 08:27 AM
Problem fixed by "downgrading" the NI Motion version to 8.3.
I think maybe version 8.4 isn't compatible with PCI 7342
