02-23-2006 03:32 AM
02-23-2006 03:55 AM
02-23-2006 04:14 AM
02-23-2006 04:22 AM
02-23-2006 04:51 AM
02-23-2006 05:02 AM
03-19-2006 11:40 PM
Mr.Jochen ,
sir ,you said that some weeks ago you have used M-Series boards to control two synchronized DC motors with a loop rate of 4 kHz , please mail me the vi of that application . was it in real time labview , i am able to operate the PMDC motors in labview itself i.e to switch on and off , run in forward and reverse mode , brake it , but to control the speed of the motor with pulse width modulation , the average voltage applied to the motor is flickering and is not stable. i am using A3949 full bridge motor driver circuit for my application i.e closed loop speed control of two pmdc motors with pxi 1010 system and labview. please suggest me on this , i have tried the same with the real time labview also , but there was hardly any change from the latter one .
please suggest me on this and i request you to send me the vi for the appication which u have developed for a reference .
thanking you
deepak
03-20-2006 02:23 AM
