point move
if anyone have the example code of motion moved by point move,please send it to me!thanks !
Message 1 of 8
(4,391 Views)
Could you please be a bit more specific with this request? What is a "point move"? Which hardware and software are you using?
Thanks and kind regards,
Jochen Klier
Message 2 of 8
(4,388 Views)
I use PCI-7330 motion control to drive a tow-aixes platform. NOW i want to get a example that can dirve the motor move step by step!And on the font panel i can push the buttons then can move the toe motors in four directory move! So i need the example code! thanks!
Message 3 of 8
(4,383 Views)
Please tell me, which development environment you are using. C, Visual Basic, LabVIEW, LabWindows/CVI,...?
Jochen
Message 4 of 8
(4,381 Views)
use labview ,motion asistant.
Message 5 of 8
(4,378 Views)
I think the Virtual Joy Stage.vi, that can be found in the LabVIEW examples directory should be an appropriate example for your purpose. Please use the example finder to search for this vi.
Jochen
Message 6 of 8
(4,371 Views)
Virtual Joy Stage.vi that can not be found in my examples! Could you put it online or send it to my email kelvinczh@163.com ?thanks!
Message 7 of 8
(4,369 Views)
This example can be found in the following location (might vary on your PC):
\National Instruments\LabVIEW 8.5\examples\Motion\FlexMotion\Jostick Control.llb
If you can't find this or other motion examples there, then there is probably no LabVIEW support installed from NI-Motion. In this case please start the installer for NI-Motion again and install the LabVIEW support.
Jochen
Message 8 of 8
(4,362 Views)
