position drift during the stepper motor controlled back and forth motion
Hi everyone there,
I get a headache position drift problem during the stepper motor controlled back and forth motion. I have been wroking on the problem for the last two weeks, and still can not figure it out. So I write down here my problem in hope of getting some clues from those have some experiences in stepper motor motion control.
My goal is to use a stepper motor to drive a beam flage fixed onto the shaft to go back and forth for a certain angle, and this back and forth motion needs to be stable and reproducible within hours. With the SMD1 stepper motor driver, I only need to send in a pulse train to control the number of steps(the pulse frequency defines the stepping rate), and another pulse to controle the direction (i.e., cw or ccw). To do this, in LabView, I used the counter of the DAQ board to produce a finite pulse train to step the motor, and used one digital line to produce a pulse to switch the direction every 500ms, the timing is contolled by the software.(I used the oscilloscope to monitor these two pulses, the pulse train produced by the counter looks very stable, and delay between the pulse edges of the direction pulse and the pulse train is also very stable within 500ms. There seems no software timing problems at such a long delay.)  And this labview controlled motor appears to work perfectly as I required, the motor steps a defined number of steps at one direction, and then steps back at the origin position. But after running for a few minutes, the back position shifts gradually(I can not observe a obvious shift at the first few minutes) with repect to the origin position(the position I start running). I looked it up at the manual and also the website, I got a clue that this might because the motor steps at the resonace frequency of the motor and hence misses or takes extral steps sometimes. So I changed the steping rate from 1Hz to 1000Hz to see if the shift disappears or gets smaller at certain frequency range, but the shift always exists.
I did observe the shift got smaller within the same running time when change the step model from full step (1.8degree/step)to half and quarter step model. According to this, the motor did miss steps (or pulses) during running, the quarter step model has smaller shift due to the smaller steps.  But I also noticed that the motor always shift at one direction, no matter I started with clockwise or counter-clockwise, this seems really strange to me. Because the motor should shift at each direction with the same probability if we assume the motor missis steps randomly.
There is something must be wrong, either the labveiw program or the motor, but I don't even know a clue of this weird shift problem. And because of this, I haven't made any progress in my lab for the last three weeks. So any suggestions could be very helpful for solving this headache and will be really appreciated.
Thanks a million in advance and Merry Christmas!
Li
(6,774 Views)
Are you using any kind of accel or decel profiles?
(6,759 Views)
Hey, Brian Beal,
Thanks for your quick response. "accel" and "decel" mean acceleration and deceleration, am I understanding right?
If yes, then I don't have these in my LabView program, I just generate one TTL pulse train and one TTL pulse with LabView and send them into the SMD1 stepper motor driver.
The pulse train steps the shaft, and the other switchs the direction.
Yesterday, I confirmed that if the motor steer always at one direction either CW or CCW, then the stepping were very stable, no missing or extra steps happen for hours.
And I also observed that the motor took one extra step  from time to time when the direction changes. And this only happens when the direction switch from CW to CCW. (bizarre!)
I guess this indicates that some pulse noise happens when the motor switch the direction too often.  But I just don't have any clue for irregular extra steps.
(6,750 Views)
Just because your DAQ is capable of generating pulses, that doesn't mean that the motor, which has inertia, can react to them.  This is one of many reasons why DAQ cards are not good choices for motion control.  Your direction pulses are changing instantaneously, but the motor can't change direction instantaneously.  You need to have some kind of accel and decel.
(6,742 Views)
Could you tell me more about accel and decel, and how to add this into my labview programm?
(6,661 Views)
