problem with Ni 7344
I use the PCI 7344 card from NI and I have a problem.
In computer with WinXp with service pack 2 under MAX i cannot initialize board it brings a warning that i must upgrade firmware but firmware is latest 6.1.5. When I choice upgrade firmware it's bring error -70025. On computer without Sp2 every thing is ok. Is it possible that it is problem wtih sp2 ?
(3,226 Views)
Hello.
The error information for error 70025 is related to the Return Data Buffer, which should not be involved with a motion firmware change. Do you see this modal error as soon as you boot, or does this happen only when you try to upgrade the firmware?
A few things that I am curious about:
Does this happen as soon as you boot the machine? Do you go straight into MAX and try to check the firmware status? If not, be sure to do this, then try to update the firmware. If you are going straight to MAX after a boot, then check to see if the board is in the power-up reset state. Open up MAX, click on the board, and switch to the Status tab at the bottom. If the red LED is lit, then the board should be in the correct state.
If the problem persists, then I would try to run a repair on the NI-Motion 6.1.5 installation. Just go to the Windows Add/Remove programs window and select National Instruments Software.
I have not seen any specific issues with Motion firmware and Service Pack 2. A colleague has a SP2 machine with the latest verision of Motion and all is well on that machine.
Also, is this the same board that is on both machines, or is it a different board?
Just in case, here is a link to the driver downloads page, if you need to uninstall/reinstall and would like them
Colin Christofferson
Community Web Marketing
Blog
(3,214 Views)
