retrieve coordinates from scattergraph by clicking on a data point
I would like to be able to retrieve the coordinates of a data point in a scattergraph by clicking the data point (coordinates to be used in the app). Is there a method to achieve this?
Message Edited by Anorad on 06-05-2006 02:33 PM
(3,147 Views)
Hello Anorad,
You can add a cursor on a graph and use the Cursor.Position property node of the graph to determine the X and Y coordinates. See an attached VI for a simple example.
Hope this helps and good luck with your application!
Shakhina P.
(3,123 Views)
