Wayne,
unfortunately there is no way to reverse the analog feedback on the
board. The best solution I can think of would be to subtract the analog
feedback signals from a reference voltage by adding an analog
subtracter to the signal path of your feedback signal.
E. g. if the voltage range of your feedback signal is 0 - 5 V you could
subtract this voltage from a 5 V reference voltage. The result is the
reversed voltage.
Jochen Klier
National Instruments Germany
