software limit and find reference
With a PI-7342 are the software limit enabled during find_flex_reference  moves?  This can cause problems because, during this move the origin is not setted and the zero is fixed at the axis position at powerup or reset.
Thanks for your answer
(5,918 Views)
Could you please give us more informations about what you want to do, what software you are using in order that we can help you?
(5,904 Views)
Hello Mathieu,
I use a NI-7342 motion controller board and Labwindows CVI 2009 but my question is not linked with any programmation language. It concerns the behaviour of the firmware of the board.  The board allows to use software limits and limit switches.
If software limits are defined and loaded during the board initialization, the origin of the axis is defined at the current position at powerup. So I wish to know if software limits are active during the  find_flex_reference move. This can be a problem, because the software limit can stop the find movment as the zero is not allready at the right position.
Thank you for you interest to my question
(5,897 Views)
Hello jfcoupat,
You could find the information that you need in NI-Motion Function Help : Start->Programs->National Instrument->NI MOTION->Documentation->NI-Motion C Reference Help
You should be able to enable or disable limits in your program.
Regards
(5,891 Views)
Thank you Mathieu
So I need to disable software limits  before refernce move and enable them again just after?
(5,888 Views)
