solidworks assembly not working in interactive test panel
I'm trying to run a simple simulation in which there are a few motors. Following the steps as suggested by the videos on http://www.ni.com/virtualprototyping/training.htm , I'm trying to run the motors in the 'Interactive test panel', but there is no motion in solidworks corresponding to it. There are no errors anywhere and there is a position error in the status tab. Weird thing is that the button showing if position error occurred does not switch on although on the side, there is a position error and the encoder position remains zero.
Please suggest a way out.
(6,603 Views)
I get the same issue
see the following
Where can I find  the example for softmotion 2012 and solidworks 2010 or 2013 x64 ?Because the example provided by Ni is about softmotion 2009  and there are diffrent between 2009 and 2012  in Set interface. According to the example  provided by Ni I can't get the same results as the example .There 3d model can't be controled by labview. See the Figure as follows.
(6,598 Views)
Accepted by topic author Ro91
I  have solved the problem !See the figure as following:
(6,569 Views)
Thanks a lot. It worked.
(6,555 Views)
