solidworks assembly not working in interactive test panel
hello
after configuring both solidworks and labview to control an assembly, and after the successful deployment of the assembly, there is no errors no problems but simply when I start the simulation nothing moves in the simulation.
please i need help
(3,218 Views)
What is your hardware setup?
Can you see if these steps follow your problem?
https://forums.ni.com/t5/Motion-Control-and-Motor-Drives/solidworks-assembly-not-working-in-interact...
Eric
(3,141 Views)
thank you for your reply ,
the problem is that when i tried to simulate a simple model it worked, but when i did all steps again in the principale project it never worked. i want to know what does it mean "the step size" and how to correct this problem (see the screenshot)
thank you
(3,071 Views)
Try reducing the MAximum Step Size by following the information in this link.
Assembly Properties Dialog Box (NI SoftMotion)
https://zone.ni.com/reference/en-XX/help/371093K-01/nimclvfb/swmodelproperties/
Hopefully, that clears up the issue!
Eric
(3,059 Views)
