stepper motor control - missing MG17Motor ActiveX object
I am trying to contrl Thorlabs TDC 001 using LabView 9 SP1. Whe I follow the tutorial to create an ActiveX control(http://www.thorlabs.com/images/TabImages/GuideToLabVIEWandAPT.pdf), I can't find the MG17Motor option even though I have installed Thorlabs APT.
Does aanyone kknow how to solve this?
Cheers!
Message 1 of 9
(10,601 Views)
I think it's a problem with registering *.ocx files in Windows 7 (64-bit). Anyone?
Message 2 of 9
(10,596 Views)
Hi notimperial,
Some Active X controls are specifically written for 32 bit machines. It is worth checking with Thorlabs whether you can run these on a 64 bit machines.
Have you tried it on any other machine with different specs? Did this make a difference?
Mahdieh G
National Instruments UK&Ireland
Message 3 of 9
(10,574 Views)
I used attached Labview code to manage stepper motor control (TDC001 Thorlabs) to translate a sample in my setup, but since some time I obtain an error constantly (attached log). This translation system still works properly with thorlabs software, it also worked with this code, therefore I am really confused why such an error occurs. I just got started with Labview and programme wasn't created by me, so maybe someone explain what is wrong.
Thank you in advance, Vasili
Message 4 of 9
(10,549 Views)
Please use a new thread for this post as it is a new issue.
Mahdieh G
Message 5 of 9
(10,547 Views)
I think there is a misprint in the Thor guide. It says look for MG17Motor but actually the example then shows using MGmotor.
Message 6 of 9
(10,253 Views)
I have NRT 150 stepper motor and BSC203 stepper motor controller from Thorlabs. I could control the motor using ActiveX and invoking MG17Motor ActiveX. But ActiveX gives very little freedom (changing step size, halt time etc). So if any one have written a VI for this, please share with me. Thanks.
Message 7 of 9
(9,864 Views)
hello
i am hadi(akbari) .i have started work  on labview from 15 years ago.
i want to do labview important
project.
can help me to this.
thanks
Message 8 of 9
(9,483 Views)
can you share your VI? I have the same hardware and a PC 64wits with LV 32 bits, but i cant access to the BSC 203
Thanks in advance!
Message 9 of 9
(6,726 Views)
