stepper motor controller
I am a labView novice so any advice would be greatly apprecialted.  I am needing to write a VI to to control a stepper motor.  I would like the motor to move to a position selected by the user.  Down the road I would like it to do more but I need to crawl before I walk.  I am using an old Velmex NF90 series stepper motor controller.  I also have a VEXTA stepper motor.
I have the velmex manual which lists the controller commands but I have having difficulties in how the commands will be implicated into the VI.
Any advice or links would be greatly appreciated. I have tried searching or help on the topic but I might of missed something.  Thanks
(7,179 Views)
How are you communicating with your motor controller? Are you using the third-party drivers found on our website for the Velmex NF90?
If you're communicating with it through serial, you will want to check on using NI-VISA, the NI software that establishes serial communication.
Ravi A.
National Instruments | Applications Engineer
(7,155 Views)
I have a NI USB 6008 DAQ.  I can't use the old drivers for the NF90 because the version of labview (of the drivers) isn't compatable with the version i'm using.
(7,148 Views)
this is a basic program i wrote for my stepper control it should work for your needs too
(7,137 Views)
You have a newer version than I do (10.0.1).  Can you either convert the VI to an older version or post a couple JPEGs?  Thanks
(7,133 Views)
This should work.
Ravi A.
(7,131 Views)
let me know how you get on, lm working on 2d array at the moment so i can control four stepper motor at a time with pulses
(7,121 Views)
