stepper motor
I currently am modifying the position control loop example that came with Labview and i have the motors turning but it is very jerky and acts like the pulse timing is off.  I am using a 9501 module with a standard nema 17 4 wire 24 volt stepper motor.  I was wondering if anyone knew some paremeters that would work with the motor.  I was looking for the following paremeters:  Position loop period, spline update period,  pos period/spline period, minimum pulse width, spline period/pos period, spline period/step period.
Thanks for any responses.
(6,010 Views)
Hi mgoat,
What version of LabVIEW are you using? There is a known issue with the VIs in 2010 for the 9501 which have some timing issues. Take a look at this document for the recommended example VIs: http://digital.ni.com/public.nsf/allkb/095FC58BB279E4178625778A0056E048. Let me know if this is applicable to you. If not, we can continue troubleshooting.
(5,995 Views)
Thank you for you response, i am using lavbiew 2011 and the link that was posted gives me an error on the page which will not open.  I think i have the parameters about right but and still struggling on what level of microstepping is good for a high speed application.  Also for some reason on the initial move the motor jumps back in the oposite direction then moves toward the correct direction.  I am using a modified version of the Position Control (Open Loop) example.  If you can give me any insight it would be much apprecieated.
(5,992 Views)
Extra period at the end of the link.
Try this:
-AK2DM
(5,989 Views)
Thanks for you response, we actually used this link to base our FPGA off of.
(5,986 Views)
