stepper
hello,
Have you got a solution or exemple to control stepper motor whith NI DAQ and CVI ?
BcGam
(3,204 Views)
Sorry, we do not have examples or source code to control stepper motor with NI-DAQ and CVI.
However it is possible to create application for axis control with a DAQ board (PCI 6221) under CVI, but using the softmotion development module and LabVIEW Real Time.
Otherwise to achieve your application, the best solution consists in using Motion controller (PCI/PXI 73XX).
With Motion controller, it will be easier and more efficient to develop your application. The advantages of using these solution are the possibility to use the Ni-Motion Library and NI-Motion Assistant to develop your application without programming.
For more information you can check the following links
http://zone.ni.com/devzone/conceptd.nsf/webmain/1C6F53CB2B79ECE086256F7A007B2D74#3
http://sine.ni.com/nisearch/nisearchservlet?nistype=default&ddown=3&filter=%2Btaxonomy%3A%22Example+Code%22+%2Bsw%3A1802+%2Bhw%3A6&q=
Best regards
Alexandre Dycke
National Instruments France
(3,189 Views)
