still have problem running 1 axis vi
Thanks Amaury, but when loading the vi, it could not find "load Target Positionh.flx","Start Motion.flx", Board id", Axis to control.flx","Motion Error handler.flx". Really, is there any step by step guide on learning how to communicate to my flexmotion 6C and the UMI flex 6. urgently need help, very lost in my current project
(3,078 Views)
If you are missing all of these VIs it definately means that you do not have the LabVIEW support installed in NI-Motion.
Did you go through add remove programs as described in my previous post? If this doesn't work uninstall NI-Motion and reinstall it. Use a custom install and make sure that support for you version of LAbVIEW is being installed.
Once you have it installed you will find countless examples and tutorials in our Developer Zone
Hope this helps.
Please let me know if you continue to have problems.
Amaury Rolin
NI Application Engineer
(3,078 Views)
