suport drivers pci-7314 to windows xp
Hello
I have a board pci7314 I would like know how is possible use this board in a system with windows xp and using labview 8.5. Because I supose that only exist drivers to compatible with windows NT.
How san I solve this problem.
(4,447 Views)
Please look here and here. This should answer your question.
Jochen Klier
(4,445 Views)
NI-Motion 8.3 download page (http://www.ni.com/download/ni-motion-8.3/2597/en) indicates that it supports legacy controller cards such as PCI-7314. A quick test seem to suggest that it is not the case - PCI-7314 is not recognized as an NI card on a Win XP machine with NI-Motion installed. Am I missing something?
Yes, I know I should not be using antique electronics.
Thanks!
(3,605 Views)
NI-Motion 8.3 does not support the 7314. I don't know where that list of hardware is coming from, especially because it contains hardware that has never even existed. I am trying to determine how to remove the list entirely and replace it with an updated one.
If I can find one and you want to try it, I can send you an old version of the driver. However, it is only supported on pre-XP Windows OSes.
(3,600 Views)
