Hi Greece,
If you are looking to make a move similar to the move outlined in the image you have attached, I would recommend making S curve moves. With an S curve move, the velocity profile is not a simple trapezoid but rather a curve in which the rate of change of velocity is smooth and differentiable.
For more information on S curves I would look at chapter 4 of the NI - Motion User manual, in which the different type of moves are outlined.
(The NI Motion User Manual should be installed with the motion driver, and a shortcut can typically be found on the start menu.)
Let me know if this helps,
Robert
Applications Engineering
