use Labview to control two Picomotor actuators successively through Model 8753 iPico driver
Hello All,
I want to use Labview to control two Picomotor actuators(belong to channel A ,C) successively through Model 8753 iPico driver.Since the example VI's
(Application.vi) from Newport's website just control one actuator at one time, so I copied the example code, thus there are two repetitive sections (see the attachment) in
the while loop structure. The test result was that two Picomotor actuators moved to respective target position circularly. And I found the test was correct when two Picomotor actuators belonged to different address. Can anyone tell why ,what should I do? Any assistance with this matter is greatly appreciated.
Best Regards,
Message 1 of 1
(6,054 Views)
