Motion Control and Motor Drives
vector move not moving
I believe that I am setting the parameters correctly for a vector move, but the system does not move, so I must be doing something wrong.
The system
Two axes in the X direction with independent control (not slaved)
One Y axis.
System works perfectly for either X axis (both motor simultaneously moving) or Y axis moves.
System works perfectly for Multi-Start axis moves (coordinated start, but not coordinated end)
Vector #1 selected to be:  X axis on X, Y axis on Y, X' axis on Z.
System does not start motion when Vector move is requested.
The system is in a clean room and heavily used for the code that is working, so I cannot have access whenever I want.
From looking at the NI manual, the only difference in the example shown from my code is that the vector space definition is made in-line with the move VIs
I initialize the vector at the start of the program.
I doubt that is the problem, but I will try that later.  I would appreciate other ideas prior to testing later today.
Any thoughts or ideas are appreciated.
(3,344 Views)
jspaarg,
Can you check to see if the example VI,"Three Axis Move with Position Monitor.vi", works?  Also, if possible can you attach your code (or a snippet of code that reproduces the same problem) to this forum.
Lorne Hengst
Application Engineer
(3,333 Views)
I can try the example on Friday.
I got it running today by putting putting the "Configure Vector Space" VI just prior to setting the parameters (mode, speed etc).
I don't know why it shouldn't work if I configure the space in an initialization at the beginning of the app.
Thanks for the thought.  I am heading to an NI seminar tomorrow.
(3,328 Views)
