voltage range for PCI-7344
I am using PCI-7344 4 axis servo/step motion controller for windows. I want to know about minimum and maximum range of voltage this board can handle or what range i can use with this board. Please help me out with this.
thanx
yogesh
(4,339 Views)
Yogesh,
here are the specs:
Analog Output range:
-10V to +10V
You can set limits for the DAC output in MAX (Axis Settings -> Miscellaneous)
Analog Input ranges:
-10 V to 10V
0V to 10 V
-5V to 5V
0V to 5V
I hope this answers your question.
Jochen Klier
National Instruments Germany
(4,331 Views)
The input voltage of all digital inputs, including encoder and limit/home switch inputs, should be limited to +5V with reference to digital ground. The 73x4 have protection circuits against higher voltages but still there is risk that the board will be damaged.
(4,328 Views)
The UMI-7774/72 (778558-01/778556-01) has 24V isolation that you can couple with the PCI-7344 if you need better protection.
Here is a link to the UMI's data sheet:
http://www.ni.com/pdf/products/us/niumi7774_031016.pdf
Rodger S.
(4,324 Views)
Rodger
Thanx for the help and the link. It works
yogesh
(4,320 Views)
Jochen
Thanx Jochen
yogesh
Message Edited by yogesh_patil79@yahoo.com on 04-06-2005 03:28 PM
(4,315 Views)
