what are hardwares needed to control my servo motor?
I have cRIO NI9024 + NI 9118 and I want to control my servo motor (480V 7500W 48Nm) that its like in this link.
what is the options to contol it?
- if using EtherCAT. What is the model of drive that compatable?
- if using its drive by connect it to module. What is the model that compatable?
Sarmad.
(3,732 Views)
Sarmad,
Regarding your questions:
We have a selection of EtherCAT servo drives available for your consideration.
As for the specific model, it will be best if you determine that yourself based on the motor specifications.
You will want a servo drive interface. I can't tell if the motor you've linked is single or double encoder, but it looks like you will either want the NI 9514 or the NI 9516, respectively.
Austin
Staff Software Engineer
NI
(3,709 Views)
Thank Austin.
my motor is single encoder and 380V 7.7kW 20A its look like AKD-P02407 is suitable.
so you tell my that it is not nessesry to use AKD with NI 9514 and I can use my drive?
I'm new user of Labview. what is the way to make the motor rotate with earthquake data that every interval of time give an accereation or position ?  is that posible?
(3,703 Views)
Sarmad,
I believe if you have a drive that comes with the motor, the NI 9514 module should allow you to use the third party drive. I believe it should be possible to rotate the motor with the earthquake data, but both of your questions would actually be excellent questions for a sales engineer. You can contact our sales engineers at the following number:
(888) 280-7645
Austin
NI
(3,669 Views)
