windows 2000 upgrade from win98--will i have problems with my pci-7344, pci 6110e & ni5411?
I am running win98 with my Labview 5.1. It running fine, but I would like to upgrade the os to windows 2000.
When I was running a check of the hardware, win2k said that the following hardware may not run:
pci-7344, pci-6110 & ni-5411.
will i need new drivers?
will i run into any problems?
any suggestions?
thanks!
Byron Golden
Allied Geophysical Labs
U of Houston
(2,912 Views)
Byron,
You should not have any problems when you upgrade your OS. Depending on what driver versions you have for that hardware, you may want to go ahead an upgrade your drivers anyway, though. The drivers for these devices are all available for free from our website at:
Current Driver Versions
http://digital.ni.com/softlib.nsf/webcategories/9AD71162B755F0E786256BBC005F001A?OpenDocument&node=132060_US
Try that and let me know if you have any trouble.
Scott R.
Scott Romine
Course Development Engineer
(2,906 Views)
