windows xp drivers for pci motion card 7314?
hi,
i'm trying to install this card onto a computer which already has labview 7.1. so far, have tried motion 7.6, 7.5, and valuemotion 5.02. the card is detected as "other pci bridge" device under the hardware manager. after installing these packages, and doing a search for the drivers it never installs.
it is also not detected under max.
any help would be appreciated, thanks
(3,515 Views)
Hi Icdd,
What OS are your running this Motion Card on because it is not supported in windows XP? For more information on the driver versions for particular devices, check the Knowledge Base article linked below.
http://digital.ni.com/public.nsf/allkb/782E7400A9FE22A68625731C005C973A
My apologies for the inconvenience this may cause you
Best wishes
Rob L
NI Applications Engineer
UK & Ireland
It only takes a click to rate this message 😉
(3,501 Views)
