-10845 error from AT-MIO-16-H9 trying multiple point AI aquesition
I am using AT-MIO-16-H9 card with CVI 4.0.1 and driver 6.1 under win98 operating system
resentely i have reinstalled this card to a new computer with the same software. Within one of my programs I am using a function AIAcquireWaveforms for timed data sampling. after the reinstalation, i'm getting -10845 error. As well as i understand it has to do with some timing controll. please advise me how to fix this problem, or, alternatevely, which function can I use for timed data sampling.(DAQ_Op also does not work and leads to the same error code)
YURI
(2,531 Views)
Greetings,
Is your board working at all, or do you receive an error with every operation? Does the Test Panel also return an error? Is this new computer also running Windows 98? Since this board was functioning correctly in a different computer, I am guessing that you are dealing with a driver issue. You should consider uninstalling and reinstalling NI-DAQ.
Spencer S.
(2,531 Views)
