10Msps Analogue Input Options with NI
Hi
My project require a DAQ to read voltage signals from a CMOS array at 10Msps.
However, there seem to be only one stand-alone DAQ with NI that has sampling rate this high, PCI-6115, but our lab uses compact PCs without PCI slots.
Then there's CompactRIO platform module NI-9775, but in it's description it only buffer samples at 20Msps but send samples to PC at 4Msps ???
The total I/O requirement is:
- Analogue Input at least 10Msps per chan (simultaneous to all channels), 14bit, 2 channels, AI task must be retriggerable.
- 3 counters at least 10MHz each, all counters must have input / trigger / arm / output channels, CO task must be retriggerable (both arm and trigger).
Is this achievable with NI ?
Thanks in advance !
(2,319 Views)
Hey 2A91312E,
I can't answer your question fully, as I don't know all NI equipment by heart. PXI Scopes exists, starting with a maximum sample rate of 60 MHz. I'd call NI Sales if I was you, they should know all devices they sell...
10MS/s is quite much, I would not expect a USB device to support this.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(2,285 Views)
