+/-10V analog input myrio
Dear All,
I am using myrio and it has two +/- 10v differential analog input on connecter C and 4 0-5V single ended anolg input on connectors A and B. My application has three sonsors which ranges from positive to negative. Is there a way to increase the number of +/- analog inputs. Can I use the two differential +/-10V to get four single ended +/-10V or can I modify the range of the single ended analog inputs to measure +/- instead of 0-5V.
(5,120 Views)
Hi @mawad,
As far as I know, there's no way of using a differential AI as two single ended AIs, due to the circuitry (which makes it differential - see this White Paper https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/analog-fundamentals/grounding-c... ) which allows the input to be dealt with in a differential manner being inside the myRIO already.
What I would advise is to use a summing amplifier to create a voltage/level switcher. This can allow you shift your signal - so if your sensors output between -5V and 5V, you can shift the range of signals up to 0-10V, and then use an amplify to amplify the signal by half, so it is in the allowable range of the single ended Analog Input (0-5V).
The web pages below should help with this.
The Summing Amplifier
http://www.electronics-tutorials.ws/opamp/opamp_4.html
What analog circuit i should use to shifting a signal from -5..5v into 0..10v?
http://electronics.stackexchange.com/questions/225889/what-analog-circuit-i-should-use-to-shifting-a...
Hope this helps!
Amy
Amy K
National Instruments UK & Ireland
(5,070 Views)
Many thanks, Amy. This is one option. The other option that I can use two myRio. Will it be okay in this case?
(4,929 Views)
