1200 LAB-PC NT
Is it possible to use 1200AI card AND Lab-PC+ card at the same time ?
I am traying to use them on a Windows NT PC, but when I go to MAX and try "Test Resources" for 1200 , I get the message "Card is not responding at this basis adress " (or something like that).
I can not change any setting for 1200.
(2,761 Views)
Hello;
You shouldn't have any problem on installing both DAQ devices together on the same machine.
Try the installation of one DAQ device at a time, and make sure it passes the resource test before you install the second device.
Also, uninstall whatever version of NI-DAQ you have installed on that machine, download the latest available version (6.9.3) from NI web site, and install that version of the driver.
Try the 1200 on different slots of the same machine, and ultimately, on a different machine to test the hardware itself.
Do the same for the Lab-PC board.
Hope this helps.
Filipe A.
(2,761 Views)
