120v with harmonics
I understand that there are suuplu outhere're that can do 120v with up to 31 th harmonics.  However, they are expensive.  I want to use fpga to to generate ewaveform, but I cant get 120.  I need about 1 amp as well.  What are all the options? Pardon my iPad typing.
Kudos and Accepted as Solution are welcome!
(3,177 Views)
Hi jyang,
What AO module are you using? You will likely need an amplifier and transformer to create the signal needed.
DylanC
(3,143 Views)
Right now, everything is up in the air.  No DAQ has been selected yet, but I will probably use a PCI FPGA card.
(3,132 Views)
