16 differential signals mesurement
Greetings from Argentina!, I'm using a NI USB-6218 to mesure 16 analog signals from floating surces, in differential mode. I have a practical problem, in order to avoid erratic results I must use 2 bias resistors to Ai GND for each signal, that means I need 32 resistors!???, We chose this ADQ device because we needed a compact adq system but using all this resistors si not practical at all. Do you have a simpler solution?, Is there any conexión accesoire that includes the resistors to GND?
Thanks and excuse my english...
(3,307 Views)
Accepted by topic author paulArgentina
a few of these will keep it nice and tidySmiley Wink
(3,300 Views)
Thank you very much!, the faster answer ever.
(3,292 Views)
NI could do a better job of promoting them! they are pretty sweet
(3,285 Views)
