1MHz sample rate for PCMCIA DAQ card
I am designing a notebook based test system that requires 1MHz sampling rate for data acquisition on a single channel. Does NI make a PCMCIA card with 1MHz sample rate? If not, is there a way to achieve that by programming? Thanks.
(2,917 Views)
Hello mchips:
There is a card called NI PCMCIA-5102. It is a PCMCIA high speed digitizer that can sample up to 20MS/s. Although the functionality is a little different, but it might be useful for your application. Please advice if this helps.
(2,909 Views)
