2 analog outputs using Daq Assistant.
Daq Pad 6016 USB
2 analog output channels.
2 analog voltages from -10 to +10V for control of devices
I turned the sampling frequency down pretty low for operation.. I
would like to use two analog output channels simultaneously.
In Daq Assistant window, it will allow me to add another channel. How
do I add control and asign it to this channel? Then I will have two
sliders for two channels (one for AO0 and AO1)
(3,593 Views)
Check this VI
It generated 2 outputs on 2 AO channels simultaneously
(3,587 Views)
Hi Expert..
I would like to view and use that example program 2 analog ouput using Daq assistant above,but my Labview version was 7.0.Could you please write in 7.0 format version please..
(3,487 Views)
(3,471 Views)
