-200284 error message when calling DAQmxReadAnalogF64() using a USB-6210
I am trying code a CVI application to communicate with a USB-6210. I want to start the acquisition to acquire 30 samples and then collect them. My problem is when I call the function DAQmxReadAnalogF64() I get this -200284 error message. In a nut shell the error message means the data has not been acquired yet. It says I should make sure my start trigger is configured properly. I was trying to use the internal clock to start the acquistion. I figure I did not set up something properly.
In the function DAQmxCfgSampClkTiming() I set the sampleMode to DAQmx_Val_FiniteSamps which I thought would make it collect the 30 samples (number_of_scans=30) when I called DAQmxStartTask(). That does not work. When I set sampleMode to DAQmx_Val_ContSamps I can collect the data. Below is a stripped down essential of my code:
 returnAcq = DAQmxCreateTask ("myAcqTask", &acq_taskHandle);
 returnAcq = DAQmxCreateAIVoltageChan(acq_taskHandle,physicalChannel, "acq_channel",DAQmx_Val_Diff, minVal, maxVal, DAQmx_Val_Volts,"");
 returnAcq = DAQmxCfgSampClkTiming( acq_taskHandle, "OnboardClock", sweepsInterval,DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, number_of_scans);
 returnAcq = DAQmxStartTask (acq_taskHandle);
 returnAcq = DAQmxReadAnalogF64(acq_taskHandle, -1, 5, DAQmx_Val_GroupByChannel, Data_readings, number_of_scans, &read,0);
 // Clear the task
 DAQmxClearTask (acq_taskHandle);
I guess my question is: Am I set up so the internal clock will start the acquistion when I call DAQmxStartTask()? I thought when I set the second parameter in DAQmxCfgSampClkTiming() to  "OnboardClock" this would make it use the internal clock.
Thanks in advance for your help,
Don Pearce
(3,741 Views)
Accepted by topic author DPearce
Don,
You are correct, your task is configured to be using an internal sample clock with a software start trigger.  The error description points out several common reasons why people might see this error.  What is the value of 'sweepsInterval'?  I believe that as configured DAQmx should be clocking data in at the rate (in Hz) specified by sweepsInterval.  By passing -1 into the numSampsPerChan input, I believe that DAQmx will attempt to read all samples for a finite acquisition (30 in your case).  If you are running less than 6 Hz, the read could would timeout before this data was available.
When configured as continuous, what values is passed back in the sampsPerChanRead parameter?
Dan
(3,737 Views)
I looked at it again and realized that sweepsInterval was wrong; it was in sample time instead of sample rate. I wanted to take a sample every 1.67 ms and I had sweepsInterval= 0.00167. So when I changed that input to 1.0/sweepsInterval everything was ok. Looks like it was the ole loose nut behind the keyboard problem. Thanks for you help.
(3,728 Views)
